Hello there!
As some of you may know I recently bought an original pair of SWF slim indicators a few weeks ago, for my 63! The look identical to the similar aged Hella part on the outside, but inside they are completely different! :roll: :?
The Hella assemblies require a large hole drilled in the wing for the upright mounted bulb, with two smaller bolt holes either side to secure it down
My units have a horizontally mounted bulb, that does not require a hole to be drilled in the wing for. It seems that the only holes that they need is a bolt hole, and a hole for the positive feed. My problem with this way of fixing them on is that the only thing stopping them from turning on the spot is the wire. This im sure cannot be correct?:wink:
I cant believe that at factory they would have two different types of wings in manufacture, one for each type of indicator! :lol:
Can anyone suggest what is going on? Or what to do to fit them correctly? :?
Cheers!8)
This picture shows the holes in the top of the wing for the Hella lights! Sorry it is so zoomed out but I stole the photo from Lenny Copp!:oops: :lol:
Sorry!:wink: In my defense, I now spend all my spare time looking through the pictures on the restorations page! :lol: :beer:
RoRoVw
I had exactly the same problem with my '63.
I bought an NOS set of front indicators from a guy in Germany via The Samba. Mine are Hella and came in the original box all wrapped in tissue paper complete with fitting instructions. They are similar to your SWF units and have the horizontal type of bulb holder and same fixing to the wing. I puzzled over these for quite a while when it came time to fit them. It's obvious that when fitted there is very little to prevent the whole unit twisting on the surface of the wing. The instruction leaflet is dated November 1960 so I can only assume that this was the very first idea that VW had for fixing the indicators and when it became apparent in use that they moved about, they altered the fixing to the later style with a vertical bulb and large hole in the wing. It's interesting to hear that both SWF and Hella were using this fixing style and that one wasn't an alternative fixing.
My solution was to use the later, vertical bulb holder with the nice, new, shiny amber lenses and chrome tops and screws from the NOS set. It's worked very well.
Doesn´t the bung part of the rubber base gasket thingy stop them turning? I had some like this and I don´t rmember it being a problem.
RoRoVw
Yes I think that's the idea but it's a fairly insignificant bung and with only one fixing bolt onto the wing it won't take much to allow the whole indicator unit to move about.
RoRoVw wrote:
Yes I agree!
There is nothing to stop the whole unit form turning!
I did have a theory that they the type fitted to USA bound cars from 58-60, but these had clear lenses and my orange ones are original!
Something else that has occured to me that VW used to offer a kit in the 60s to add slim indicators to your semaphore beetle. I suppose they may have designed it in a differnet way so that you did not have to drill so many hooes in your wings?
Thats almost certainly true, I would think.
Not sure whats on my car, but its been converted. I´ll take a look sometime.
Can´t really see why they´d turn. You aren´t planning on swinging off them, or are you worried about the vast aerodynamic forces at work at 50+ miles an hour?:d
IN2VWS
Those lights were not only used for turn signals on Beetles. They were also used as brake lights for cars and trucks, as can be seen in this 1960's Hella catalog.
RoRoVw
54 Gertie - Since you don't have indicator holes in your wings already I think I'd be inclined to go ahead and fit the SWF units as they were intednded and then see how they stand up to normal useage. At least you won't have to cut the huge hole in the wings that the later units require. If it turns out that they do move out of position then you'll still have the opportunity to find the vertical bulb holders and then cut the large holes to fit them. I didn't have that option since I already had the fitting holes in my wings.
Or fit the indicators in the headlights - thats my plan.
Ooh, very cal-look... :wink:
Oh. A-hardy-ha-ha Robert. :wink:
It looks more original than wingtop ones.
It has these at the moment and I have promised myself from the start of the project that the car is not finished until correct indicators are fitted! :wink:
Cheers for your help!:d
kdf38
<< double post >>
Texas
Nov. 1947 +
Febr 1949 shell
kdf38
If there is a problem with them moving, you could get some of removable glue/cement that is used to attach logos to cars now and put a spot or two on the rubber first.
Texas
Nov. 1947 +
Febr 1949 shell
kdf38 wrote:
My thoughts exactly.
kdf38 wrote:
Yes, I agree! I have decided to fit them how I think best and see how well they stay put on their own! If they need any other attention I will sort it out...
:wink:
All factory-fitted European model indicators from August 1960 were Hella and with two threaded studs to mount to the wings. The bulb holders were always vertical. Hella and SWF both started producing these retro-fitable lamps (the type you have), mostly with horizontal bulb holders from 1960 onwards. They're very easy to find as NOS units compared to the 'proper' ones.
Rich Oakley wrote:
so when would these have been made? 60s?
Cheers!:d :d
Cheers!:d :d
Yes, 1960 onwards, and possibly as early as 1958/9. The horizontal bulb arrangement and single threaded stud allowed for the retro-fitting of this style of indicator to earlier (Split/Oval/late 50s) wings without drilling a big hole in the top of the wing to accept the vertical bulb holder. They are definitely 'aftermarket' parts.
