Hello there!
As some of you may know I recently bought an original pair of SWF slim indicators a few weeks ago, for my 63! The look identical to the similar aged Hella part on the outside, but inside they are completely different! :roll: :?
The Hella assemblies require a large hole drilled in the wing for the upright mounted bulb, with two smaller bolt holes either side to secure it down
My units have a horizontally mounted bulb, that does not require a hole to be drilled in the wing for. It seems that the only holes that they need is a bolt hole, and a hole for the positive feed. My problem with this way of fixing them on is that the only thing stopping them from turning on the spot is the wire. This im sure cannot be correct?:wink:
I cant believe that at factory they would have two different types of wings in manufacture, one for each type of indicator! :lol:
Can anyone suggest what is going on? Or what to do to fit them correctly? :?
Cheers!8)
