Judson53
Were can i get the corect master cylinder for my 53 from?
cheers
andy
If you contact John Maxwell via The Historic Volkswagen Club,he has details of a supplier who stocks a perfect replacement part.I believe John used one on his '53.
Apparently identical to original.
Judson53
Thanks very much,will do that :lol:
Ovalbug
I was led to believe that the 50-66 bus master cylinder is the same as the pre-54 Beetle one ie the one with a fluid reservoir mounted on top? :?:
'63 Karmann Ghia RHD
'72 1302LS Karmann Cabrio RHD
cheers
andy
Judson53 wrote:
i thought yours was a standard? Cable brakes?
www.vwoval.co.uk
Jules
Ovalbug wrote:
I think you are right in that the Bus Master will fit and work in the correct way.... but it's bigger, 22mm I think!!!
We have a very similar cylinder at KK but 19mm, might be closer to original?
Judson53
JULIANROBINSON wrote:
sadly they were replaced with hydrolics many years ago!:cry:
Ovalbug wrote:
Thats what I have done on my '53... the reservoir is a plastic one.. but only i will know..[-x
www.vwoval.co.uk
Ovalbug
Me too, have got a bus master cylinder and plastic reservoir (in case the original metal one doesn't fit on the new cylinder) for my '53............
The OE cylinders are still available as its also a Porsche 356 fitment and you can get Ate ones , but they are a lot of money.....
Didn't know the master cylinder bore was different though! :lol:
Jules
Ovalbug wrote:
We now have repro '4 bolt' cylinders... great quality and cheaper than the ATE ones!
The STOCK POLICE will have their heads under that car at Stanford Hall..................
You will be sussed in seconds:wink:
