aircooled
21 years ago
My dash has two 1/8 inch dia screw hole the orginal owner made to install a rear view mirror on the dash. What is the best way to fill these holes?
58BUG
21 years ago
As with most things there are number of ways to do this. The best way would be to weld the holes closed however on the dash this would involve alot of work due to the heat spreading. A cheaper/quicker way could be to use some filler or a product like 'magnum steel' which once filled can be sanded and then sprayed.:twisted:
