Morning all,
Right, it's MOT time.....
Bear with me because this is the first time I've prepared everything on my 53' Oval for its MOT myself. It's spent the last 2 years in mothballs and I'm getting the old thing ready for a trip in October. Here's a list of what I've done. Is there anything I've missed that they're likely to fail me on?
Lights / Cab checks:
Tail: OK
Semaphores: - OK
Headlights: Full & Dipped OK as well as speedo bulbs. Do they check beam adjustment too? I suspect this might be out...
Horn: - OK
Screen-wash: - OK
Wipers: - OK
Wheels bearings: seem OK
Brakes Front / Rear (new): OK
Handbrake: 2 clicks, OK
Shocks: OK - no weeping
Tyre treads: all OK
Axle beam brushes: - no excessive movement so OK
King & Link-Pins: - no excessive play, greased, so OK (Have also greased the front axle)
Track rod ends / gaitors: no excessive play or wear, so OK
Steering coupling: - Not sure on this one, but if it's perishing on the rubber I'm looking for then it wasn't too bad.
Steering box: - Don't have excessive play in the steering so I left it alone
Brake fluid reservoir - topped up.
Tin-worm all round: solid car, so no worries there.
I've also given the bug an oil change for good measure. If anyone has anything to add that would be really helpful.
Fingers crossed, eh?
Cheers,
Klaus
