Here are some pictures of the completed chassis restoration. It is coated in red oxide primer which is the original finish. Ray and Bryan have remade the headlight buckets and are fitting the aluminum skin to the front. Denzel put a oil/tar impregnated burlap type material between the steel chassis and the aluminum skin originally to avoid electrolysis - Ray is looking into replicating this material.
Got the brake parts - actually a combination of Fiat Topolimo and Multipla style master and wheel cylinders. Has aluminum/webbed brake shoes. Ray had some brake lines made up.
Gauges and gas tank sender are in to North Hollywood Speedo - they have the silkscreens and will clean and get all mechanisms working - and will also make a new tach cable and oil temp line (ether filled?)
Apparently the rear brake/tail and front turn signal lights are from Lucas - I am currently trying to locate some new/better ones.
Ray is in the process of making up some mufflers/piping/heater boxes for the engines using my complete set as a pattern. He has already made most of the engine tin pieces that are different than stock VW - I think he has 5-6 Denzel engines to build for various folks....
Dropped off interior to upholsterer - trying to find the red vinyl with burgundy specs in it as original.
There are more posted on thesamba.com gallery coachbuilt section.
