A new big project.
A 1967 21 window samba.
Needs a lot of work but is still restorable.
The good, solid roof.
The bad, everything under the roof... :lol: :lol: :lol:
As all the other aircooled Volkswagens is the 1967 samba also a one year model so a lot of small details who are diffrent as a 1966.
This bus is an original Austrian bus but is already 10 years in Belgium.
In his last drivable period it was used as a camper, so they pull out the bulkheadpanel... :cry:
But it is in good hands now.
 Afbeelding 16.jpg You have insufficient rights to see the content.  afbeelding 3.jpg You have insufficient rights to see the content.  Afbeelding 12.jpg You have insufficient rights to see the content.  Afbeelding 21.jpg You have insufficient rights to see the content.
Long side panel is going out, too rusty and too much dents.  Afbeelding 20.jpg You have insufficient rights to see the content.  Afbeelding 22.jpg You have insufficient rights to see the content.
Also the right side panel needed to be replaced.
The only problem, they don't make 1967 panels cause it haves a diffrent feulcappressing, and the lock is on the feultank.
But, I found a NOS one! :beer:  Afbeelding 23.jpg You have insufficient rights to see the content.  Afbeelding 150.jpg You have insufficient rights to see the content.  Afbeelding 660.jpg You have insufficient rights to see the content.  Afbeelding 153.jpg You have insufficient rights to see the content.  Afbeelding 152.jpg You have insufficient rights to see the content.
As the bus came from Austria it was full of tar inside the wheelarches and everywhere underneath!
About one millimeter of tar everywhere underneath! 😶
A hell of a job to remove this, believe me!
I hated it realy...  afbeelding 24.jpg You have insufficient rights to see the content.  Afbeelding 25.jpg You have insufficient rights to see the content.  Afbeelding 26.jpg You have insufficient rights to see the content.  Afbeelding 27.jpg You have insufficient rights to see the content.  Afbeelding 046.jpg You have insufficient rights to see the content.
The bus had an accident in the past and was very bad repaired on the drivers side.
The nose had filler one some places for about 2 centimeter!  Afbeelding 29.jpg You have insufficient rights to see the content.  Afbeelding 031.jpg You have insufficient rights to see the content.  Afbeelding 032.jpg You have insufficient rights to see the content.  Afbeelding 035.jpg You have insufficient rights to see the content.  Afbeelding 036.jpg You have insufficient rights to see the content.
Tar on the ground and on my shoes....  Afbeelding 690.jpg You have insufficient rights to see the content.  Afbeelding 692.jpg You have insufficient rights to see the content.  Afbeelding 693.jpg You have insufficient rights to see the content.  Afbeelding 695.jpg You have insufficient rights to see the content.  Afbeelding 704.jpg You have insufficient rights to see the content.
cool thing, but a shit load of work.....:shock: :shock: :beer:
hopeing for weekly updates here :d :wink:
Yes Andi, A lot of work but it's a 21 window....
About everything on the drivers side is cutted out, even the A-pillar was bended and repaired very bad...
And the chassis was rotten....
Got a good chassispart from a donorbus.  Afbeelding 771.jpg You have insufficient rights to see the content.  Afbeelding 777.jpg You have insufficient rights to see the content.  Afbeelding 772.jpg You have insufficient rights to see the content.  dog leg 001.JPG You have insufficient rights to see the content.
No doubt it will end up looking fantastic like all the other restorations you do Pascal!:wink:
Thanks!
I removed the paint and bondo of the roof for sandblasting.
The rear side is cleaned now and haves no tar and grease anymore, so a dry bus! :lol:
The roof needed small welding on 2 places.
The bus is back on his wheels!:beer:  Afbeelding 786.jpg You have insufficient rights to see the content.  Afbeelding 791.jpg You have insufficient rights to see the content.  Afbeelding 792.jpg You have insufficient rights to see the content.  Afbeelding 796.jpg You have insufficient rights to see the content.  Afbeelding 799.jpg You have insufficient rights to see the content.
Rear floor is finished now and a lot of dents are now out of the left frontnose.
Still a lot of work to do.
Ready for Mr Sandman! :lol:
 Afbeelding 818.jpg You have insufficient rights to see the content.  Afbeelding 819.jpg You have insufficient rights to see the content.  Afbeelding 821.jpg You have insufficient rights to see the content.  Afbeelding 827.jpg You have insufficient rights to see the content.  Afbeelding 830.jpg You have insufficient rights to see the content.
And weldingwork...  Afbeelding 860.jpg You have insufficient rights to see the content.  Afbeelding 861.jpg You have insufficient rights to see the content.  Afbeelding 862.jpg You have insufficient rights to see the content.  Afbeelding 886.jpg You have insufficient rights to see the content.  Afbeelding 929.jpg You have insufficient rights to see the content.
Bus is sandblasted and my garage is a bit bigger now! :beer:
Bus is painted with epoxyprimer.
Right chassis is still very bad... 😞
But I found a NOS part! :beer:
I tried the repro but won't fit at all...
You're warned...  Afbeelding 940.jpg You have insufficient rights to see the content.  Afbeelding 942.jpg You have insufficient rights to see the content.  Afbeelding 945.jpg You have insufficient rights to see the content.  Afbeelding 948.jpg You have insufficient rights to see the content.  Afbeelding 950.jpg You have insufficient rights to see the content.
Outside is replaced.
Inside too.  Afbeelding 956.jpg You have insufficient rights to see the content.  Afbeelding 958.jpg You have insufficient rights to see the content.  Afbeelding 961.jpg You have insufficient rights to see the content.  Afbeelding 996.jpg You have insufficient rights to see the content.  Afbeelding 997.jpg You have insufficient rights to see the content.
And up!
Front U-profile is replaced.  Afbeelding 999.jpg You have insufficient rights to see the content.  Afbeelding 1003.jpg You have insufficient rights to see the content.  Afbeelding 1005.jpg You have insufficient rights to see the content.  Afbeelding 1006.jpg You have insufficient rights to see the content.  Afbeelding 1007.jpg You have insufficient rights to see the content.
And up! :beer:  Afbeelding 1010.jpg You have insufficient rights to see the content.  Afbeelding 1013.jpg You have insufficient rights to see the content.  Afbeelding 1014.jpg You have insufficient rights to see the content.  Afbeelding 1019.jpg You have insufficient rights to see the content.  Afbeelding 1016.jpg You have insufficient rights to see the content.
Some NOS parts and some repro! :beer:
Those bare metal parts are very high quality and fitting perfect, bought at Serial Kombi France.
All four jackpoints are replaced.  Afbeelding 1026.jpg You have insufficient rights to see the content.  Afbeelding 1021.jpg You have insufficient rights to see the content.  Afbeelding 1023.jpg You have insufficient rights to see the content.  Afbeelding 1029.jpg You have insufficient rights to see the content.  Afbeelding 1028.jpg You have insufficient rights to see the content.
And up.  Afbeelding 1031.jpg You have insufficient rights to see the content.  Afbeelding 1033.jpg You have insufficient rights to see the content.  Afbeelding 1034.jpg You have insufficient rights to see the content.  Afbeelding 1035.jpg You have insufficient rights to see the content.  Afbeelding 1036.jpg You have insufficient rights to see the content.
Some new belly pans. :d  Afbeelding 1038.jpg You have insufficient rights to see the content.  Afbeelding 1039.jpg You have insufficient rights to see the content.  Afbeelding 1040.jpg You have insufficient rights to see the content.  Afbeelding 1041.jpg You have insufficient rights to see the content.  Afbeelding 1042.jpg You have insufficient rights to see the content.
top job on both: the car and the shop.
