Whilst my wife was baking the most incredible mixed spice marble cake with toffee fudge icing, I escaped to the garage for some more precision based action (cake was fantastic BTW)
I had a little parcel arrived this morning from my good friend ‘Fuzzyduck’ which contained a selection of crank shims to allow me to set up the correct end float. Cheers Fuzz!
It took me several attempts to find the right combination of 3 shims to get the end float just where I wanted it at 0.1mm, which is dead in between the tolerances in the Bentley manual. Sad I know, but I just can’t help myself…
Anyway, first up was to clean the flywheel…. With my new found friend!
Which did a splendid job of cleaning up the friction surface where the clutch disc sits.
I then polished the surface of the flywheel where the oil seal sits to ensure a good seal.
In preparation for my new genuine original VW oil seal!
Next up was to prep the gland nut. Some say use a new one, others say the original one is fine if in good condition….. I cleaned the original one, inspected the fibre washer for wear, re-greased the roller bearings then added a little loctite to the threads just to be on the safe side.
Now for the fun bit!
First on was the paper gasket – I gave this the slightest smear of K2, just enough to dampen it, but not enough to smear or squeeze. If nothing else, it stopped it falling off during assembly!
With the shims and gasket installed, I added a smear of K2 to the outside of the new crank seal and inserted it into the case as carefully and as straight as possible using a block of wood and a mallet.
I was amazed at how difficult it was to get in – I’m confident that it won’t leak from the outside part, that’s for sure! The books say that the early seals are fully home when they are flush with the case, but mine still sat proud even when ‘home’.
This was a concern to me, but it simply wouldn’t go in any further….
As a last resort, I took a look at a picture I took when I first removed the flywheel, and to my relief, saw that the original seal from the factory was proud by the same amount also! Phew!
At this point I took out my massive tool…. In order to apply sufficient torque to the gland nut, you need to find a way to lock the fly wheel.
I bought a flywheel lock too which will come in handy for the front pulley and other lighter duties, but I’d heard of a couple of broken cases around the stud hole where they fix and didn’t want to risk it.
So…. I took a long length of box section, drilled two holes to match the holes in the flywheel for the clutch plate and braced it against the engine stand.
Simple, but very effective!
Now for a VERY large torque wrench!
217 ft/lbs is the factory torque figure, yet many books say to do it tighter – some up to 300!! - I chose 250 ft/lbs as a nice round figure and torqued it up with ease, thanks to the length of the wrench and the sturdiness of the brace bar.
And now for the moment of truth – re-checking the end float.
I used a magnetic dial gauge like so…
With the crank pushed all the way in, I set the dial at zero….
Then with it pushed back fully the other way, took another reading!
That’ll do nicely, sir!
A word about measuring end-float accurately…. I found that pulling the edges of the flywheel against the outer edge of the case with your hands highlighted a small element of flex in both parts which depending on how hard you pull, distorted the readings. After an awful lot experimentation, I found that it is best to push the flywheel from the centre, not against the engine stand which is mounted to the case flange, but against the front end of the case as if you where trying to squeeze the case. This removes any possibility of flex. Likewise, I tapped the crank pulley end of the crank gently with a lock of wood and a mallet to ensure it was fully pushed the other way, rather than pulling on it the other end. After doing it this way 5 times, I got exactly the same readings every time.
Anyway – here it is, another small step forwards.
Party on!
