Had the day off work today so was able to make some more progress.
The next area to address was the rocker assemblies. Although I’d already given them an initial bath in the jet fuel, I wanted them ‘cleaner’. I’ve been experimenting with other cleaning products to use as an alternative to the oven cleaner – not for any other reason than to have an alternative in the arsenal.
I boxed everything up and took them to work and whilst the technicians were at lunch, I spent some time on the soft brass wire wheel we have fitted to our bench grinder. This did a great job of getting the carbon and ground in much off, although it did leave them looking a little dull.
When I got home, I tried my next chemical – ‘Wonder Wheels’ alloy wheel cleaner. I can report that it works very well indeed – not as good as the oven cleaner, but not as aggressive so better for use on precision machines surfaces.
It was excellent at cleaning up the rocker nuts, bolts and other hardware.
More results pics in a minute!
If you recall, I was intending to you the original valve adjusting screws as they didn’t look too worn, but on close inspection, a few of them were beyond service…
I couldn’t find anyone selling 25/30hp adjustment screws – all the usual vendors just offered 40hp ‘61> items. Some research however told me that they are in fact the same and the only difference is that the locking nut on the later versions is a 13mm nut rather than a 14mm nut. So I crossed my fingers and ordered a set of later ones which thankfully I can confirm are identical to the early ones.
They were however covered in a dark greasy coating that I didn’t want getting into the motor – so, as per usual….
And the results of all this rocker cleaning?
With some careful lubrication, they went together a treat!
I can’t express how pleased I am with how they turned out – although they owe me about 6 hours in total….!
Remember these from some distant cleaning frenzy of yester-year?
The push rods have to go inside the motor before the rocker assemblies can be mounted.
For those that don’t know, Volkswagen inserted wooden dowels inside the early pushrods to control oil flow and you can hear them rattling around if you shake them when they are clear of oil.
However, a couple of them had become a little lodged down one end, and when I blew down the pushrod hole, it was clear that there was a restriction as the air passed through much slower than the others.
To cure this, I squirted brake cleaner down through the hole then shook the heck out of the tube until the dowel came free which cured the problem and released the restriction.
Naturally, before installation, I filled them with oil to give things a head start when it first fires up.
And covered the ends in assembly lube to help the cam.
Thanks to the careful set up of the cam follower guide plate inside the block before I put it together, the followers slid home perfectly with satisfying precision.
The 14mm mounting bolts are torqued to 14 ft/lbs.
Doesn’t the second picture look fantastic?
Next up is to set the valve clearances to 0.004”. The mini ratchet ring spanner made this a nice job to do, although in true LT style, I obsessed about this for ages to get them perfect, even knowing I’ll be doing them again when the motor has run a little. Oh well…
At this point it is worth mentioning that the ideal set up for the adjustment screw to valve stem relationship is to have them off set a little. This eccentricity ensures the valve turns during operation to keep an even mating surface at the valve seat.
Next up was to mount the crank pulley – and I was sure not to forget the pulley tin that must be mounted first!!!
I soon discovered that the tinware screws were not exactly clean… but fear not – they are now sparkling!
The front pulley tinware was also a mess, but came up well after a jet fuel bath and scrub.
To remove the corrosion deep within the pulley groove, I gave it a gentle brush out with this handy drill attachment.
The pulley came up nice and clean too.
Note the screw thread on the inner shaft that is designed to return oil to the crankcase. Nice design.
Making sure the wave washer is not forgotten, I torqued up the nut to 85ft /lbs using the flywheel lock tool that I must say is most splendid!
Last job before I called it a day was to fit the oil cooler. This was already clean from a few days ago, so it was just a case of fitting the new seals which fit snugly into the recess’ in the top of the case.
Leaving me with something looking an awful lot like a 30hp motor!
Getting there slowly.
