First job today was to remove the motor from it’s trolley stand and ‘rest’ it safely in the corner of the garage. It was now the turn of it’s best friend the gearbox to sample the lofty heights... As I knew that today was going to be a messy day, and even though it was only 3 degrees, I set up camp outside.
To remove the other axle tube, I first needed to send out a search party to help find the bolts!
After some brake cleaner and a tooth brush, I could at least now see the bolts. This initial clean of the joint also reduces the chance of getting crud in the box.
With the axle tube and side plate removed, I could now see the spacer gaskets – just like the other side, two thick ones and a thin one.
Oh look – that’s where the axle goes!
Next up was to remove the rest of the hardware – mainly the mounts and starter motor, which is the correct dated original item. The mounts are in great shape and can be used again.
Why are there two drain plugs?
Gearbox looking pretty bare now!
At this point I knew I had some cleaning ahead..... crack open the jet fuel chaps!
What a 'tool!'
After a very long time with the jet fuel, brake cleaner and my usual assortment of brushes, I got things back to their 'natural' state.
As the pictures show, it was now getting dark and very cold, so I called it quits for the night and wheeled the box back into the garage to keep warm.
Next job will be to clean the actual gearbox - joy!
