Right then..... normal service is resumed!
Even though it was -5 degrees and looked like this in the garden....
I wrapped up warm and headed on outside for some Oval loving!
To recap on the previous work done, here some catch up pics.
Repairing the threads of the fuel pipe nut and getting it back in the master cylinder. Don't worry, I'll replace the grommet where it passes through the chassis.
And the bottom of the fuel tank protected in sealing wax.
I used my new bench grinder with a soft brass wire wheel to clean up the rear solid brake lines. Quick before and after shot...
I've been collecting a few parts recently which look very nice indeed waiting patiently in the departure lounge.
Here's a few of the bits n bobs I've acquired.
Correct screw type brake switch.
And yes, of course I did! (it was rude not to)
Cork gasket for the oil filler.
New rubber grommets for the heater cables and clutch bowden tube.
Which of course wouldn't be the same without a NOS heater cable.
Here are my new shocks against the old ones.
Some correct 'wind up' style OEM Porsche 356 (same item) axle boot retaining straps.
New nose cone selector shaft boot.
Which is correct according to all my manuals and parts books, yet this is what I removed from the car..... strange.
Almost tempted to super glue the original cable conduit boot back together, but I might just buy a new one.
I bought a new rubber grommet for the fuel tap lever which I fitted next. It is shiny and golden as I;d just sprayed it with sealing wax.
Which will be connected up to my new genuine VW fuel tap.
A nice new pair of OEM rear transmission mounts.
And a new 'OEM' front trans mount.... I'll come back to this in a minute...
I offered it up to the transmission to find this...
OEM? ?? ??? Whatever! What is disappointing is that the reputable supplier of this part assured me that as it was much more expensive than similar ones on the market, it was the real deal and fitted correctly. I beg to differ.
Anyway - I wouldn't insult my car by even showing it to him, so it'll be getting back in the post tomorrow.
Whilst the rear mounts had indeed gone very soft, I'd always thought that my front mount
was very usable. Yes, it was a little perished around the edges, but it hadn't gone hard as I first suspected, and was';t all soft and chewy either, so I decided that I'd rather have a used but serviceable original one than a new piece of crap and set about cleaning up the old one.
I couldn't resist cleaning up the earth strap with a little oven cleaner - you know, for old times sake.
And after giving the original bolts and washers a clean up on the wire wheel, mounted it back home on the trans to fight another day, covered in sealing wax of course...
Spot the difference in the fit?
That's all for tonight folks - just a quickie before my 'nuts' froze!
