With precious little else I can do until parts arrive, I turned my attention to the wiring cover which you'll see by my signature, is now (or was) an item I was looking for as mine was well and truly kippered.
My research has shown that replacements are simply not available, so I decided to see if it was at all possible to repair my existing one without having to bandage it up like a mummy...
After a visit to Dad which saw me leave with all sorts of clamps, glues and bits of hard wood etc, I came up with a cunning plan - crazy, but it just might work!
I thought I'd start with the easier stuff first such as the frayed, split and de laminated anchor points etc...
Dad lent me some super thin cyanoacrylate adhesive which is only a fraction of the viscosity of water and has incredible capillary action and can find it's way deep into joints with ease. He also gave me some kicker which when sprayed on, not only sets the glue instantly (bloody hot too!) but allows the surplus glue that is still liquid and floating on top of the joint to set like a cement filler for added strength.
I then took two square rods of ridgid hardwood, courtesy of Dad again, and wrapped them in cellotape..... why.... because the glue simply will not adhere to the tape!
Then, sandwiching the damaged and de laminated area very tightly with clamps and the strips of wood....
I then 'wicked' the adhesive thoroughly into the joint until it would accept no more, let it settle and soak for about 20 seconds, then zapped it with the kicker setting it like concrete.
Which yielded fantastic and very encouraging results!
The repair is incredibly strong and rigid, so spurred on with this result, I got a little more adventurous and had a crack it this almighty mess...
Yet again - fantastic results!
Exhilarated with bravery, I thought I'd put it all on black and see if it would work against this nasty piece of work...
This section required a two stage approach - firstly I did the usual with the two strips of wood.
Then where it had split along the radius of the moulding, I had to clamp it on one side with a marker pen which closely matched the radius - wrapped in tape again of course!
I was delighted with how this section turned out!
And then for the biggie.... Do I attempt to join both halves together using this method?
Ah, why the hell not. This involved getting Mrs LT to hold the two halves tightly aligned and pushed together whilst I carefully fed adhesive in, inch by inch whilst spraying it with the kicker. This was done both sides - but as it was a difficult job that required two pairs of hands at the same time and and with the timing being so critical, I didn't stop to take pictures, but boy oh boy am I over the moon with the results!
Considering what I started with, I'd call that a result!
Due to the curved shape, the joint is really strong and I couldn't help myself from testing it with a few trial flexes!
I'll need to go over all the joints with a blade to tidy any rough edges up and remove some of the white and shiny residue etc, but other than that, it's usable now and another big tick in the originality box of preserve not restore etc.
Whether I do some proper cosmetic work to the front face, smoothing the join and re-painting it I don't yet know.... we'll see.
Not bad for an evening I'd have otherwise spent on the sofa waiting for parts!
