gipf
  • gipf
Hello all, I'm having some problems with my carb. I've been trying to set it up but when I screw in the volume screw nothing happens, I can take it out completely and it runs the same as if I screw it right in.
Has my carb seen it's last days? 😞
Piet
  • Piet
Check n° 1 : the tip of your screw is broken off and still in the carb body.
Try to blow it out with compressed air.
Check n°2: intake air leakage, check manifold with brake cleaner spray while in idle mode. When idling goes up in RPM, there's a leak.
But your engine needs to be tuned correct first, valves/timing/etc
Proost! Peter.
