Does anyone know where I can source a set of early 4 bolt wheel cylinders for my '51, the only place I have found so far is Kaefer Nostalgie but at $700 for a set of 4 :omg: I don't think so....
early 356 ones look the same.... just as expensive :shock:
Welcome to the world of Beetle restoration!!!:shock:
Look here one time:
https://klasse356.secure.gearhost.com/catalog/showItems.asp?Category=BRW
69project
i know its probably frowned upon but i just fitted oval ones as they were so expensive!
Car less.....
Just like gentlemen who prefer blondes,:oops: purists prefer original:omg: !!!
Just shop around a little bit and you still can do deals:roll: !
Old Blue
ianmac wrote:
Running a vintage Beetle is getting as expensive as running a Porsche:shock:
heb623 wrote:
says the guy who wants to put a 356 or Okrasa into his car :rofl:
:twisted:
If the original is missing an Okrasa is a superb substitute.
:oops: I may be a little guilty for suggesting this to ET:oops:
Maybe I can make Rob happy by saying that I am not[-x going to use an Okrasa kit!
Because more power is needed fo the saxomatic this was my first option!
But now after realising this is not "historical" correct I made the decision it's going to be something else, but I am not going to say what!:p
So patience asked!!!
to George:
Front and back wheel cilinders of 19,05mm. were only used from 3/50 till 5/50
The rear changed into 15,88mm. from 6/50 till 12/53
Front wheel cilinder always were 19,05mm.
:oops:
to George:
Front heel cilinder always were 19,05mm.
heb623 wrote:
Yes,and ?
1951 - NOS 4 bolt wheel cylined. - £offers
For all split window beetles with hydraulic brakes.
19MM.
The 19mm wheel cilinders are indeed for all split window beetles yes! In front but not in the back!
Right or wrong?
19MM. [/i]
Right or wrong?
heb623 wrote:
Right,but where does it say it's for the back?
GKL 7 wrote:
Ok George, it doesn't say , so I assumed you meant they were good for the back too!
I am wrong and you are right, ok?:oops:
Blame it on the language difference:roll:
However I am stilll convinced that my English is better than your Dutch, isn't it?:p
https://www.ate.de/generator/www/com/en/ate/ate/themes/30_ate_classic/ate_classic_en,tabNr=4.html  what would be better than the original manufacterer remaking them
Catalogue page 294 on the thumbnails will take you to the Beetle brake parts. I've only glanced at it but unfortunately it looks like they only sell parts from 01/54 onwards :-(
https://www.ate.de/generator/www/com/de/ate/ate/themen/21_kataloge/download/ate_c1_classic_katalog_uv.pdf
chthemonkey
im sure if there's a big enough order they'll make them.
Yeah, maybe when you make an order of 25.000 pieces!!:omg:
Is it not better to order the wheel brake cilinders of a 356, they are still available from 1951!
Maybe not original (but the same:oops: ) but alot cheaper than the making of those ..... other ones!!:shock:
