I was wondering if you could use something like a modified Volvo item on the cylinder itself, sealed up with an inlet grafted onto it, and then have that connected to the original reservoir to fill up/check level with. Bay Type 2s have something similar IIRC, a little pot under the dash to top up and a bigger reservoir directly on the cylinder under the van, plugged into the two inlets.
