southerndeluxe
well hi one and all well ive been out in the workshop ive have taken the bull by the horns and decided the split section had to come out.
to this????
now got the job to clean up
so what im looking for know is the lower rear screen section and vents and hinge carrier if anyone out there knows of one or has one for sale the big build is defo on the way got the bug again
Nice! Shouldn't be too difficult to get this section though? Did it change into the 70's or can you get a cut from a slightly later car?
southerndeluxe
its a june 60 car so its a small rear screen so its got to be a early car ???
southerndeluxe wrote:
Good point... :beer: Did the rear window change size as well as the side windows?
southerndeluxe
yer up till 64 they have a small rear screen then got bigger in 65
So where did the extra size come from? Because aren't the vents the same size?
southerndeluxe
im not sure ???
I think the depth and width is bigger but you may be able to modd a later bit to fit just need to chcek the radius on the lower corners.
