pics to folow.
will also post in resto thread?
car is a march 58 rhd coral red delux , as far as i can see
the reg was transfered many moon ago but it still displays the original plate.
hopefully the V5 will arrive soon showing the current reg( last owner was informed it did not have an reg allocated after transfer , DVLA in a phone call said that was wrong and they should be able to sort it from the chassis number. - and they have now taken the money from the bank so fingers crossed.
problem is i wanted an early 60's bug( small window , linkpin) to convert to a BAJA and i was offered this under the impression it was a total resto , bottom 6 inches ect , real basket case!
turns out to be a previously unwelded 58 delux!- no door drop!
this was my suprise after pulling away the carpets!
i was also a bit worried about the stae of the inside of the fuel tank seeing as it was stood for quite a few years , until i had a look, which also confirmed the date march 58!
i will hopefully put it on the road ,im doing the basics hopefully ready for an MOT,im doing minimal welding , all very good quality as if its a keeper it must be good ! but not all OG panels , but its welded so thay can be correctly fitted if your were doing a correct resto. but then wll need to decide if i cut it or sell it to fund a BAJA without destroying this one!
