I'm at the end of a (very) long restoration, and my first test drive a few weeks ago lasted for about a minute before the engine stalled - it would start again after being left for about a minute, but would then stall again as before. I subsequently discoverd that fuel is leaking from where the fuel pipe connects to the top of the carb (the float chamber is very full...). It's a stock 28 pict 1, by the way.
The carb had been on a shelf in my garage for the last few years during the restoration. but looked clean (and worked fine before I took it off the engine). I have subsequently re-built the carb and am frustrated that that has made no difference at all.
I have checked the length of the fuel pump pushrod and that's OK (I have also tried two different fuel pumps and it's the same with both of them - in addition, one of the fuel pumps was on the engine originally when it worked well with this carb); I have checked the float and that doesn't have a leak; the cut off valve appears to work (in as far as when you press the t*t you can't blow through it!). I have fresh fuel in the tank, btw. Any ideas chaps? I really want to try and get on the road at last after all these years so would be really grateful for any help!!!
