Old Blue
Choke cable nightmare. Read half way down this page:
https://forums.pre67vw.com/yaf_postst18997_Garnet-Red-1959-Beetle-Restoration.aspx
Rich Oakley wrote:
The choke cable on split window Beetles comes out on the floor tunnel by the handbrake. Later cars like the 59 have the cable knob on the dash panel. So not a direct comparison.
Old Blue wrote:
The floor choke was only on the splits with the KdF style dash layout. Rattletrap has the 'juke box' style dash and so the choke switch is on the dash as with all 'Zwitter' splits and oval window cars.
A 28PICT would be pretty much a straight swap, just need to run a feed wire from the coil to the auto choke element.
Mike Peckham wrote:
Hi Mike and thanks.:thumbup:
I'll be checking through my pile of old '60s-70s carbs.
Yet another question;
Battery covers - they are usually oblong. The one in Rattletrap is a smaller square one. I have had small square 6v batteries in the past though. When was this small suare cover introduced and discontinued. Is it infact for a Beetle. The design is the same as the oblong one.
Mike Peckham
Rattletrap wrote:
Great. was thinking about this after I had posted and realised that you will also need to adapt the metal fuel feed and vacuum pipes. The usual mod is to cut the pipe and then fit a section of flexi hose between it and the carb.
It seems a shame to cut an original pipe, but if you have a supply you'll probably not worry to much. Otherwise you can buy repro items from several suppliers (for the fuel pipe at least) so you might want to get one of those and cut that.
Hope that helps
Rattletrap wrote:
Could be, because the car is a prototype 😛
Old Blue
Could be, because the car is a prototype :p
GKL 7 wrote:
Doubt it. I have one at home, but I don't know if it came with Old Blue when Dad got it new, though I think its earlier and just something he got hold of later. I've seen these square battery covers before. Are they Beetle, and can you still get the square batteries to fit?
WHOOSH !!!
GKL 7 wrote:
:lol: :lol:
I remember having the a stuck choke cable on my 58 .i just squirted lots of penetrating oil down the tube and left it for a day then squirt some more.dont worry if the cable stretches and de coils itself .its better if it does as this will also break if free of the rust that's trapping it .wrap the cable around something and pull for your life.i cleaned the tube out with an old clutch cable on a drill .
https://www.chemodex.co.uk/store/index.php?main_page=product_info&products_id=70
Mike.
Hope that helps
Mike Peckham wrote:
Found a 28 PICT carb that looks as though its been buried in the garden for a few years!I'll see what I can do with it after giving Sunroof53's advice a go.
As you point out, the diameter of the pipes is different. I remember coming across this some years ago, and as you suggested, did cut the two differing pipes and joint together with a small length of flexi hose.:smile:
Mike.
Sunroof53 wrote:
Thanks Mike, certainly worth a try - can't make it worse:smile:
GKL 7 wrote:
Many a true word said in jest as my ol' gran used to say...
Does anyone know about these square covers, there doesn't seem to be much info on them.
Were they for early Type lls:?
Can you put a photo up of the cover for all to see :wink:
Does it look like this John ?
Old Blue
Sunroof53 wrote:
That's like the one I have anyway. What year are they?
Old Blue
WHOOSH !!!
GKL 7 wrote:
An informative reply would be nice.
Sunroof53 wrote:
Thank you for posting the pic Mike. That is identical to the cover I have.:thumbup:
Having given these battery covers some thought, I think that the type of cover fitted may have been set by what type of batteries were supplied to the factory. Most batteries were oblong, so most cars have oblong covers. Anyone other ideas:?:
Sunroof53 wrote:
Mike, should it not have a strap over fixing?
These do not have a slot at each end for the spring pull-down clamps.
Old Blue
No fixings under the back seat of Old Blue apart from a clamp and nut to hold the battery steady.
