the reason I asked about the solex 28 carb kit, recently had one of these made in China/Empi kits delivered by very well known VW supplier, which in my opinion could be dangerous to use as the pump diaphragm supplied had a smaller disc in the middle fitted which then meant the spring would sit on the rubber & I could see problems there after not too many miles,
idle screw was also too tight & too long
did get sent another alternative kit which seemed better, but a novice could/should see the difference between the 2 kits as one had plastic needle & stems instead of brass as well as the above
I recall years ago when Empi was the dogs danglers when it came to accessories etc I've still got a West Coast Metric pocket book with lots of goodies in
But im a believer in seeing humour in everything, you just have to look hard, but maybe in the case of the Empi over-riders if you haven't seen them, not toooo hard :d
steps off his orange box
10 years ago
