pootle
20 years ago
This may sound stupid, but how do you fit the mirrors onto the door hinge pin, can't work it out as the cap is solid unlike later ones which a plastic cap? Mines a 62 :?:
20 years ago
If you don't already have them, you need to replace the top hinge pin on the door you want the mirror, with a pin with a threaded head to screw the mirror on to.
Check out this section at WolfsburgWest...
Larry
20 years ago
Pootle,
Additional information: If you are not comfortable replacing the hinge pin yourself then you should really consider having a professional replace it. It is easy to do damage to the body of the car if you do not use caution.
I have replaced the upper hinge pins on both of my 1966 beetles, one drivers side and two passenger sides. I felt comfortable performing the job myself so I did it using standard garage tools which consisted of a hammer, a one quarter inch round punch, cardboard and a can of penetrating catalyst.
Hope this additional information helps,
Larry
