fiftyfour
I've had some hand fabricated panels fitted to replace the rotten ones on the door bottoms of my 54 beetle. Does anyone have any pictures or can explain where the drain holes are positioned on their undersides?
Judson53
on my 53 ive got 2 small ones on each end and one big one in the midle,could try to get some measurements it that would help
Hi ,
Here are 3 pictures from those drainholes !
The door is a split door from 1951,
but I think the holes are also correct for a oval !!
Regards,
Guido  IMG_4871.JPG You have insufficient rights to see the content.  IMG_4872.JPG You have insufficient rights to see the content.  IMG_4873.JPG You have insufficient rights to see the content.
fiftyfour
Cool! Cheers for the info guys, just what I was after.
fiftyfour
Sorry to bump this back up. Could someone post up a picture of the inside of the door bottom if poss please (taken from top looking down would be perfect). I can't see how any rain water would drip from this inner section into the very bottom part of the door (where the seal sits, as in pic above). Got a feeling my doors have not been welded up correctly. Thanks in advance.
