  • 55Kab
I'm at the stage of fitting a new rear tack strip and would like to gauge opinion and experience of others on how to reattached it to the body.
I believe orginially it was nailed into position (also held by the 3 small internal brackets) and the head of the nails leaded over. With my car about to be painted, I wondered what others had done or knew of in terms of fixing this in place?
Ninamashr on The Samba posted a pic of his car on the "54 vert dome switch" thread and it showed the use of sloted brass (wood?) screws.
As my replacement wood is hardwood I can't quite bring myself to nail it back into position and was thinking about using stainless screws, the heads of which would be leaded in.
Any comments? What have you done or what do you know has been done in the past?
Tks
(Bloody elitist oval kabrio owners...:d )
Though I only have a lowly `58, its all pretty much the same. I spoke to Klaus Hermann Meyer about this a while ago and asked him if there was a way to make the roof removeable (to facilitate future welding, paint and so on).
He said they can split the rear tack strip and use screws to hold it in place instead of nails. Its all hidden anyway when the roof is installed, so you´ll see no difference using screws. You should probably call him though.
Mine's an even lowlier '65, by then they'd given up with nails and leading etc. and the rear bow is bolted vertically into the ledge it sits on.
  • 55Kab
(Bloody elitist oval kabrio owners...:d ).
:lol: :lol: :beer:
Doesn't the edge of the roof come down and butt again the top of the rear metalwork??? I'm talking screws that go through the rear metalwork (just above the engine lid) and into the wood.
Wish that method was in place in 55, it would have made it a lot easier! BTW Rob, 'bout time we saw some more pics of your lovely black beauty.
I know what you meant - the screws hold the wood in place, but the bottom edge of the fabric hides the screws (Or can be made to do so). Thats what I think he meant anyway.
  • 55Kab
Aha, got it. The original nails (?) were leaded over though so that's what I intend on doing again.
Really? Hmmm... thats one particular bit of originality I could live without I think. Lots of advantages to being able to remove the roof without pulling out a hundred nails and trashing your trim strips!
No need for screws or nails.
There are plenty of products on the market that will bond that wood to steel forever.
And guess what, that area suffers from water encroachment,so you will kill two birds with one stone--- stick the wood in,seal the water out.
  • 55Kab
Anything in particular you would recommend George? Did Steve attach the wood in this way on the 50?
Steve didn't do everything you know:roll:
But, i think he used Sickaflex:lol:
Oh!but it won't fill those gaps:oops:
  • 55Kab
Ta, I'll tell my man to look into it. :wink:
