  • oval56
i do search the answer for my problem with my rearapron in my heb no.455 / 13.01.1950
should ther be a hole or not... and if not, was the engintin with hole or also not?
thanks
thanks
The sedan it was made from should had the hole, why not the Heb?
I guess there still was the hole in your apron.
  • oval56
hi carsten, thanks, so i will try my best 🙂 do you have the correct size of diameter??
as you know, my heb hat a wrong apron when i got it and i changed it with the correct part, but now the hole is missing :-)
usariemen wrote:
The hole starts on top of the closing sheet where the hood lock grabs in.
There is a little rounded area on top of the sheet wich is part of the hole.
The diameter of the hole is about 42 Millimeters.
  • oval56
suuuuper, :beer:
thanks carsten
