Jules
  • Jules
We've got a few real nice new products here at KK
30hp Dual Port Engine Kit £1075 Including Vat (will be £1095 when Vat changes in January)
This upper-end engine kit is engineered to original Oettinger standards, and includes everything required to make the switch. All original details have been preserved from the OEM manufactured cylinder heads that maintain the original 7.5:1 compression ratio to the reproduction Solex 32PBIC carburetors. The full kit with instructions includes:
2 dual port cylinder heads with pre-loaded valves and springs. Okrasa engine valves employ the latest in high performance valve technology. Exhaust valves feature high performance racing grade 21-4N stainless steel construction, with a friction welded, heat treated steel alloy tip.
2 dual port manifolds and gaskets
2 reproduction Solex 32PBIC carburetors
2 OKRASA style air filters
1 original style copper plated steel fuel link
1 linkage kit, your choice of original or updated CSP version
1 balance tube with connecting hoses and clamps
1956-57 Beetle Right Hand Drive floor mats £265 Including Vat
Black, 5-piece set, includes 4 floor mats and firewall mat, fits 1956-1957 Right Hand Drive Beetles, these mats are molded from original samples and are identical in every respect.
Accessory shift lock £97.00 Including Vat
The perfect anti-theft device, and nearly impossible to bypass. This device disables the gearshift mechanism while your vehicle is not in use. Our new accessory shift lock is a facsimile of the original Sperrwolf design; all elements have been preserved, can easily be painted Ivory.
We can also supply the correct rubber boot for use with these shifter locks.
Available for:
Beetle >67
Beetle 68>71
Beetle 72>79 (£107.00 Inc)
Bus >73
[quote=Jules]1956-57 Beetle Right Hand Drive floor mats £265 Including Vat[/b]
look nice but where are the 53-55 mats...??? :wink:
[quote=Jules]
Nobody needs them.
You have email Julian!
