69project
Is that the one with the new beam[-x :wink:
you will only notice the nice shiney new horn grilles :wink:
Car less.....
Last Triumph
What is the gauge on your dash?Ammeter?
Sunroof53 wrote:
Luckily it's not a guage, it's a magnetic St Christopher, so no holes in the dash! πŸ™‚
Caledfryn
Caledfryn wrote:
Couldn't agree more.
Last Triumph
Cleaned off nearly 2 decades of dust and crud today. Firstly with a dust pan brush and vac taking it from this....
to this...
Lovely patina...
Then used the typical proprietry products to cut and clean the paint back to it's natural self...
Only a start, but gives me a cleaner base to work with. I'll tackle the interior next I think?
I'm not shooting to restore, just to remove dirt and grime to releal it;s natural beauty and condition.
What a fantastic original patina you have revealed! It looks really nice like this now. The only thing, I wonder if you have to do something to seal the very fragile and thin coat of original paint and primer left over the metal. With the humidity you get in winter, especially in this country, it will permeate through rapidly to the metal and it might start to rust.
Maybe a clear coat of non-gloss varnish could be applied to seal your car against the elements? Maybe others know of another/better way to do achieve this? :wink:
You are very lucky to have a car in that state, it's history on wheels...:d
48REME wrote:
Yes, a car like this is a real joy to have, and of course it would be a real shame to have it repainted, erasing all the visual history that 48REME mentions :wink:
It is a real problem to hold a car such as this in its present state without further deterioration which, in our winter climate is difficult. I have had my '49 which is also in its original paint now for 25 years and have found a regular Waxoyl rub all over helps to keep the damp out. But you may not want to take your car around like that as it will soon look dirty. I personally feel that varnishing/laquering over the car is a like adding paint over the top, except that you can see through it. Unlike Waxoyl, you won't be able to wipe it off, and the finish will no longer be original. A DILEMA :shock:
A spare windscreen too :?:  4470139161_a1d0d3f165.jpg You have insufficient rights to see the content.
69project
im having this same dilema,my paint is even more far gone and resembles sand paper!
ive bgt collinite but have not got round to trying it yet,its not meant to be as harsh as anchor wax
even though it should never see rain etc i just worry what to use :?
Car less.....
Last Triumph
Yes, a spare windscreen... plus a treasure trove of NOS parts and OEM parts that came with it. Eachaust, heater boxes, ATE brake and wheel cylinders, gaskets, seals, trims, rubbers plus lods of other stuff - the lot. :wink:
Standard split wrote:
:idea: another good idea would be to keep it indoors all the time. and maybe to never drive it.:idea:
48REME wrote:
Agreed...but I would really start to think about clear coating it LT. Then it's protected for quite a few more years to come. :wink:
No it's not John. You just need to spend some money on proper protection. After all, we all seem to spend a lot of money on the car's themselves and then most seem unwilling to spend a little more on really looking after their pride and joy.
You just need to get something like this:
https://www.carcoon.co.uk/carcoons/index.asp
RockStock wrote:
:lol:
Nice one Chris! :beer:
Last Triumph
It is garaged in a well insulated garage attached to the house with the central heating boiler and pipes in, so as normal garages go, it's in a fairly warm and dry enviroment.
Interestingly, it has been under sheets in a UK barn for the last 17 years and the patina is exactly the same as when it came from Portugal. It was discovered and rescued from a cobbled street and brought back to the UK, then just stored until now, never driven, never registered. I've seen photo's of when it was discovered and it really hasn't changed or decayed at all.
It will only ever get infrequent use and only in the dry. I won't even be washing it with water - just wiping away road film and dust with a suitable wax/polish/spray - it's not like I'm worried about scratching the paint finish, as there's already plenty of dings and dents and scrapes on the wings etc that will need careful dollying. But I'll be leaving them unfinished and not refinnishing them as they just add to the history, charactar and originality of the car. There are more than enogh concourse restored examples out there - for which this is the perfect candidate, but for the time being, I have no intention to destroy it's virginity.
Once I've been through it, got it back on the road and MOT'd etc, I'll clean all the wheel arches off, remove all the dry mud, dust and light surface corrosion with a stiff brush, then choose a decent protection product and just cake it all over the underside, inner panels, bulkheads, inner floorpans etc - something like Dinitrol 3125, or waxoyl etc. I'm not going to underseal it, or put any other 'permanent' coating on, as this will hide the natural condition, but just something to keep the moisture out that can be cleaned off with white spirit etc in the future should plans change.
As for the external patina - I'll find a quality wax/sealent such as autoglym extra gloss protection or similar and just keep aplying it and applying it until it is well and truely drenched / soaked with it.
It's lasted well this far, so as long as it is kept dry, I'm sure it'll be fine.
RockStock wrote:
:evil: Oooof :!: Right in there – and well below the belt 😢 :lol:
… As for the external patina - I'll find a quality wax/sealent such as autoglym extra gloss protection or similar and just keep aplying it and applying it until it is well and truely drenched / soaked with it.
Last Triumph wrote:
… another good idea would be to keep it indoors all the time. and maybe to never drive it :wink:
Fact is you can treasure your all original jewell as much as possible, but once she's out on a public road with the many idiots in their buzz boxes … :evil:
And after an original car has had shunt/collision damage repaired, well, it's no longer original 😞
I do very much admire your approach to keeping the car untouched and avoiding a repaint, cars such as this are getting rarer and rarer, with restored cars becoming more plentiful :wink:
Did he really just write that? :shock::lol: :lol:
Talking gibberish – the election's coming and I want to be an MP πŸ˜›
Talking gibberish – the election's coming and I want to be an MP :p
H'mmm, yes I think so as I was thinking about a famous black 53 (or is that 50!) Split Beetle!
Think you should stand for the "We follow Rattletrap party"...:wink:
Yes,you have a lot in common with an MP.
I can see the headlines now:
'More MPs expenses claims exposed, the Rattletrap Party Transport Minister, Standard Split, found claiming expenses for ribbed semaphores, heart tail lights and period radio…':lol:
Back on topic – When you have the UK reg plates made for this so original car, it would be great if you can get the 3D type like the car has at present – they're still available :wink:
Where from John?
