First thing this morning I called in on my brother in law as he has some ‘equipment’ in his attic. He is an electronics genius and works for the ministry of defence in design and research. Whilst I spend lots of time in the garage playing with cars, he spends time in the attic designing and building lasers….
Fortunately, he has a small hobby lathe which was perfect for re-facing the commutator in the dynamo.
The chuck was able to hold it perfectly true without the need for a running centre.
We ended up removing just under 0.75mm from the surface to get down to the deepest grooves, but there is plenty left to play with without going near the bottom of the insulation grooves.
To clean the burs and crud out of the grooves, I ground the wavy edges off both sides of a junior hacksaw blade which made a great little all-in-one tool perfect for the job.
After a quick clean up, I was left with this….. good as new.
I’ve found a source for some now 2ZZ bearings which until they arrive, the dynamo, and therefore the rest of the fan housing etc is on hold.
The only other thing left now to complete the motor is the heater boxes…..
I was all ready to install the NOS items when I heard these little voices whimpering from the bottom shelf of parts saying “Please use us, we’re fine, really – we promise to be good, we’re not too rusty and if you give us some love and attention, I know we’ll be up to the job…..”
As the main exhaust was rotted through and the original heater boxes had repair pipes welded to them, I just assumed them to be junk and as I have the NOS items, I didn’t give them much thought, but I’m under no illusion as to the value of a perfect pair of NOS heater boxes, and it seems silly to fit them for the sake of it if the original items are serviceable.
So I decided to strip them down and investigate their real condition – if it turns out I can use them after all, I’ll be over the moon, as it just adds to the originality and I get to keep the NOS ones for a rainy day.
I wanted to see what was behind the repair pipes, so carefully cut them off just in front of the welds to see what was underneath and discovered the original pipes inside which went pretty much all the way forwards to where the silencer joins, but you can see why they were repaired.
I then kept cutting the original pipes further and further back until it was back to the original thickness of pipe without any rust thinness which thankfully is well into the straight section if I decided to keep the J tubes and fabricate a correct diameter replacement tube.
I then gave them a jet fuel bath to get the oily and flaky junk off.
They really were very grotty….
Now for the real test – if ever you wanted evidence of the almost unbelievable powers of plusgas, after a 15 minute soak in the stuff, every single fastener which has been rusting solid for 53 years came off without a hitch. I’d bath in the stuff if it didn’t make my hair fall out….
Anyway – I was thoroughly delighted with what I found inside – almost like new, and check out the condition of the J tubes!!!
At this point, I’m thinking that a straight pipe could be invisibly joined at the cut (after carefully smoothing off the rest of the repair pipe) and hey presto – original heater boxes! Failing that, I’ve got some NOS J tubes lined up just in case.
For those that care, here are a couple of close ups of the mechanism if you’ve ever wondered what goes on inside…
Now – this is where it all gets a bit crazy…. stick with me on this….
It would be all too easy to send them for blasting and powder coating, but that’s not in keeping with the program, so here goes….
I carried out an experiment recently to test the rust removing capabilities between Coke and vinegar by submersing a pair of old rusty body mount washers off a previous project in a small container of each fluid for a few days and seeing what came out. Whilst the Coke was pretty much ineffective, the vinegar was astonishing!
You can see what’s coming next can’t you….
The looks I got at the check out at the local super market with this lot on the conveyor were hilarious!
The bags of white powder aren’t what they look like, they’re sachets of citric acid powder to give the vinegar some extra kick. The vinegar took about a week to work the rust off the washers, which is fine, but to speed up the process a touch, the citric acid will just spice up the mix a little.
Malt, no less!
My poor bin gets some crappy jobs….
I put all the original hardware into two small plastic boxes, marked left and right and punctured a few holes in it to make sure they flood with fluid, then closed them up tight with my last tie wrap, and some PK screws to make sure I don’t loose anything.
4 gallons of vinegar and over a pound of citric acid went into the mix….
I’ll be right back after these messages…. (which might run for a day or two!)
Cheers!
