Today was fuel tank day.
I wish I'd taken a picture of the inside and bottom of the fuel tank before I started, but let's just say it looked like something between a river bed and a festival toilet on a Sunday afternoon.
I pondered for some time about whether to send it away for a clean and flush or to have a go myself.
Needless to say, I thought I'd have a crack myself first.
Before I started, I decided now the tank was out, it would be a good time to check if the solid fuel lines where clogged or not. I prayed they were clear as the idea of trying to unblock them or worse still replace them wasn't something I cherished.
I got some flexible but semi rigid fine piano wire and fed it through, bit by bit. Came out the other side no problem and clean as a whistle!
Big relief, I must say. I'll still give them a little air line action before I reconnect everything though, just in case there is a little foreign matter lurking in there.
Back to the tank and how to get rid of 53 years of sludge, varnish, gunk, rust and who knows what else was lurking in there.
Firstly, I dropped in the tank this large bowl of nuts, bolts, washers, fixtures and fittings to act as an abrasive.
I then emptied the remains of a bottle of cellulose thinners, a load of white spirit and some panel wipe for good measure - about 2-3 litres of mixture in total, then sealed the top of the tank with duct tape.
I then sloshed and shook the tank for all I was worth. Side to side, back and forth, up and down, rolling the tank over and over and over for about half an hour - bloody hard work I can tell you.
On inspection, this had loosened and disolved all the paste and gunk and some of the scale and rust, but there was still a way to go.
I drained the unspeakably grim fluid out of the tank and began phase two.
I added about a cup full of this superb and highly concentrated water based degreaser I discovered a while ago, then added about a gallon of water.
This stuff has high foaming properties and makes you feel like you're giving it a bath!
Back on with the duct tape and then more shake, rattle and roll. To the point of exhaustion. I knocked myself sick I was at it so hard, and sitting here on the sofa typing this now reminds me of the days I'd go for gold at the gym and not have the energy later to move!
I kept at it for about 2 hours until I couldn't do any more.
I peeled back the duct tape and was delighted to find the inside of the tank lovely and clean and free of all that had sullied it earlier.
The water in there was black, and there was loads of loose debris swilling round so I then flushed it with the garden hose until it was perfectly clear, removing the nuts and bolts whilst I was at it.
I wanted to dry it off as soon as possible, so switched the hoses round on my workshop vac and used it as a blower. 5 mins with the outlet hose in the tank had it bone dry.....
..... and bright orange with a fine coating of surface rust!
D'oh! :lol:
Had a quick think then came up with a cunning plan....
Why the hell not, eh?
I poured about half the bottle in, then back on with the duct tape. This time I just slowly rolled the tank around for 15 minutes makig sure I kept all the surfaces wet.
I drained this off and then flushed the tank with the hose again until it was well and truly neutralised.
Back on with the vac/blower again to dry it out.
The result?
I'd call that a win.
As it might be a little while before there is fuel in the tank again whilst I tend to the master cylinder etc whilst the tank is out, I emptied about a third of a can of WD40 in the tank so it formed a small pool in the bottom. I then rolled the tank around again to make sure everywhere got a decent coating. I'll rinse this out with a little fuel before I reinstall.
Knackered, but satisfied.
