spillo491
Hello,
I would build an old speed motor for my 62 ragtop. I'm thinking on this configuration
- kit big bore 1385
- Reichert dual carbs 28pci kit
What about it ? Any suggestion please ? I'm not skilled in engine :?
Is it better and simpler a judson supercharger ?
Regards
i would go for a mild cam if you open the engine and i would choose the 34pci carb kit instead of the 28pci
also a bit lightened flywheel and adjusted compression ratio would improve the engine
if we talk about a 40hp engine (34ps)
spillo491
Reichert told me that kit D (2 x SOLEX 34 PCI) can be used for engine type 1200
later August 1962 (sealring with 34 mm o.d.. On cylinder head intake
channel)
I have a June 62 motor so I must use dual 28pci I think
