I have not posted for a while ,but have been doing some small jobs with what time i have had .I havnt finished welding the rear apron yet as i need to get a side tray blasted.In the mean time i did a bit to the front.
Here is the little strengthener on the inner wing.Bits like these have a habit of looking ok .its only when you remove bit like these you see what going on underneath.
I made a cardboard template and decided it would be easier to make in two bits .I dont have a jenny so its a case of bending with pliers and using whats at hand.
I had to cut most of the surrounding material but seemed easier to get this bit in first.I always give the metal a quick grit blast which is what you can see on the left.
The piece of angle and the tie rod was to pull the left inner wing over but i'll come to that later.
As i did some of this a while ago i need to sort some pictures of it finished but here is one of a small repair to the left side which also needed the strengthener.I made the piece to follow the contour of the old one just using snips and a file.
