vwdude
21 years ago
:?: Help!! my car cranks when i turn the key. but there is no spark giving off. any ideas?
L8765DELUX
21 years ago
that is super easy. look at all fuses and crap. make sure the wire from the starter is "HOT" and one from there to the Pos side of coil then make sure ground is good. there is also the ING thing that you put the key in to make car go. make sure power is going to both bottom sides of the key start. if both have power and your coil in on right it should start. also This got me and some friends once. we had a 65 pooper that was rust glued together. the little contact in the distrubutor sorry spelling sucks kind of blitzed from the heat. the little contact fell out. make sure you check your condensor on the thing that has all the sparkplugs going to. make sure that goes to ground. hope this helps. spark is an easy thing to master.
The Desert Elk TINPANZERS
arizona
