Looks like a 30ps block from distance but there are no As or Xses in 25 hp or 30 hp serials. Open the valve cover and if you find the long sleeve hex nuts it is 25 hp. You might find a cast date for the block from the left side of the generator stand.
edit: and it seems to have 30ps upper cylinder tin with the "cones" on both sides of the spark plugs. All the parts that are visible (gen, pulleys, shroud?, gas pump, coil, distr, oil filler, exhaust) are incorrect for your car.
