Made some more decent progress today, so buckle up for a treat of a trip into automotive astonishment!
Seriously though – this is what happened today…
First things first, I finally managed to find the original and correct exhaust studs and hardware with the blank band in the middle – not from a VW source but direct from Porsche as they used the same component on the 356 and early 911’s. I feel somehow ‘cleansed’…
Got the jewel of the thermostat in its mounting bracket and mounted to the block.
The thermostat pushes a rod that runs up between the cylinders and links to a mechanism that controls the amount of cooling air supplied to the fan.
Here is a sequence that shows before and after cleaning, then assembly.
Next up was the cylinder head tinware which was in a right old mess. The gunk was so heavily caked on, the most efficient method of cleaning was to used a plastic scraper to remove the majority of the thick stuff, then give them a bath in the jet fuel, then a final degrease and clean in a foam bath.
The temptation to get all the tinware blasted a powder coated was very strong, but then I’d not be following the plan to preserve rather than restore, so I’m leaving it well alone.
The heater channels were next and they were equally as grotty as the head tins. These took hours to get clean as most of the filth was literally backed on, hard and crusty and wouldn’t dissolve in any of my cleaners and I didn’t want to risk taking any more paint off by using the oven cleaner, so it was literally a case of scrubbing until they eventually came up clean.
I was in a bit of a quandary about what to do with the bare metal and light corrosion, and as I’ve said, I didn’t want to be painting, coating or covering anything up. As the metal work is actually perfectly sound, I decided to give them a coating of the transit sealer I’ve discussed earlier in the thread. It takes about 30 – 40 minutes to dry, then forms and tough yet flexible amber coloured protective coating that keeps moisture out. I’m all too aware that it will attract dirt and dust, but as it is only on the external surfaces, I’ll live with that in the interests of preservation. I’m sure they’ve got another 53 years left in them…
You’ve got to love original tinware – it fits perfectly!
Apparently, the support mount from the case to the top of the oil cooler is a rare item and only fitted for a few months in late ’56 to mid ’57. Obviously I’ll need to swing it out the way when the fan housing goes on. It mounts through a hole in the housing direct to the cooler for additional support.
And finally – this is how I left it for the evening. I sense I’m on the home straight now and the finish line will soon be looming!
I’m really, really pleased!
Thanks for sticking with me!
