Little bit of an update for you....
As I now had all the parts necessary to complete the dynamo rebuild, I started from the armature and built it up from there. Forgive the plentiful pictures, but it might be of some use to someone in the future to know the exact order and orientation that all the components fit.
https://www.volksgoods.co.uk/ who supplied me with new bearings and brushes etc and a bit of help on the telephone late at night when I needed some urgent questions answering – a really great chap if ever there was one – highly recommended. And thanks to Fuzzyduck too, who came to the rescue at the eleventh hour!
I started with the refurbished armature and compared the new brushes and bearings against the old ones. Note that the modern bearings are a closed ZZ design which has a metal seal capable of withstanding high temperatures. These are size 6202-2ZZ if anyone is looking for them. They are pre-packed and zero maintenance, unlike the originals which need re-packing with special grease.
This picture shows the components in the order that they fit into the end cap of the dynamo (fan end).
With the main locator ring hard up against the circlip on the shaft, the end cap slides up against it.
Followed by the securing spacer ring which is a tight press fit. I had to use a socket to drift it home.
With everything in place, don’t forget the woodruff key...
I decided to keep the fan securing plates, shims and bolt on the end of the armature out of harms way. This end is now complete.
Note that I wrapped the armature windings with tape to reduce the chance of damaging them during assembly.
And now to the commutator end (pulley end) of the assembly... Like the fan end, the bearing end stop plate goes on first, hard up against the circlip ring.
Followed by the bearing, and then the dust shield. Now that I;m using sealed bearings, the dust shield’s only purpose is for correct spacing of the components on the shaft.
Again, the spacer collar is a press fit and needed drifting on with a socket, followed by the insertion of the woodruff key.
And there it is – all finished and ready to go back in the body.
Next up was to fit the new brushes into the rear end plate that I’d cleaned earlier.
Some of you may remember that parts of the original cloth insulation had rotted away leaving bare wires. Well, they’re not strictly bare as they are coated in enamel, but I wanted to protect them anyway. This gave me something of a quandary and I had to choose between using original new cloth braided cables which would have meant heavily disturbing the internal wiring, which might be in a work hardened and brittle state and potentially induce problems, or leave the wiring as it is and find a way to insulate the wires without disturbing them. After seeking advice from a couple of experts, they all said the same thing – leave it well alone and just add insulation where needed – which is exactly what I did.
Thanks to Dad (yet again) he had dome very fine high temp silicone tubing of the perfect internal diameter for the wire which we carefully split open, cut it to the exact length required, fitted it over the bare wires then sealed them closed again. It turned out fantastically and as the tube is clear, you can see the wire’s condition inside. Really please with this little fix that allowed me to retain all the original wiring!
And with the armature back inside...
I then cleaned up the original voltage regulator under belly....
And assembled the other end cap using the two long through bolts. Looks a bit more like it now!
With the large rear (front?) backing plate in position, it was time to fit the fan. It gets torqued up to 47 ft/lbs and I used some loctite as well, just in case.
Note that there are spacer shims to allow you to adjust the fan back spacing from the rear mounting plate which should be 1.7mm with as little run out as possible, preferably nothing visually noticeable.
After fitting the front pulley, it’s all ready to go back into the fan housing now.
Before the entire assembly is offered up to the motor, I remembered to fit an original cardboard gasket that seals the open generator stand and stops oil leaking out the top from under the dynamo. It’s helped along with a little sealer.
And after a bit of diddling to get the bottom of the fan housing inside of all the cylinder tins top edges, I finally have what looks almost like a complete motor!
I then added the genny strap and a few other bits n bobs too dull to photograph.
At the rear, I bolted up my rare and original oil cooler support stand which was only fitted for a few month at the end of ‘56 to mid ‘57. As a May ‘57 engine, mine must be one of the very last to have this device.
Next up was to fit and adjust the cooling air control ring which is a venturi style device that restricts the amount of air that the fan can draw when cold, then via a lever linked to the thermostat, as the engine reaches operating temperature, the ring pulls out from the housing a little to let the cooling air in as shown in the second picture. A really neat device.
It must however be set up correctly. To do this, the engine needs to be at operating temperature...... er...... hmmmm...... Ah, yes, let me re-phrase that – the thermostat needs to be fully open to it’s maximum expanded length, hard up against the mounting bracket.
After a quick head scratching session, I came up with a cunning plan. Whilst Mrs LT wasn’t looking, I sneaked her hair dryer out of the house and into the garage and set it up to blow hot air directly at the thermostat from the rear of the heater box outlet....
Which did a grand job of expanding the thermostat to the required fully open position.
When the thermostat is in this position, the top centre of the fan control ring needs to be set at a gap of 20mm from the fan housing. Too little and you risk not getting enough cooling air to the motor under high loads – too much and the ring can come out too far resulting in the inside of the venturi fouling the fan. I endeavoured to set it perfectly. When it is correctly set and the motor cools down, there should be a decent spring tension from the thermostat holding the control ring in the closded position.
And that, my dear friends, is all I had time for tonight – it is my birthday after all!
