Sadly, the postman didn't bring what I was expecting today so progress was limited to cleaning and preparing the gearbox.
As the ring gear teeth had taken some abuse in the past, I decided it was a good idea to replace the starter motor bush. I gently tapped out the original with a 1/4" socket and extension which was the perfect size for the bush.
As this picture shows, it is plenty worn and probably the a contributing factor to the ring gear condition.
Although it was just above freezing, I opted to work outside today in good light and fresh air - plus my cleaning job was gonna be messy! I set myself up with all my brushes and cleaners, mainly jet fuel and brake cleaner, then set to work..... what fun!
The green 'sheet' catching all the debris underneath is an old air bed that had a puncture and was responsible for probably the worst nights lack of sleep at Santa Pod last year for the 2009 VW Action show.... it was now getting it's just desserts!
It came up really well and revealed some lovely details....
This little hole is the breather at the top of the nose cone...
The bell housing came up nice - it'll be a shame to remove and replace the original input shaft seal.
And there it is - all clean!
The clutch release bearing operating mechanism was still very grotty and I wasn't happy to leave it this way...
So I stripped it down and cleaned it a little bit....
Then put it back together again, looking like it belongs on the gearbox once more!
Now was the time to flush all the sludge out of the bottom of the gearbox. I knew it was there as the old oil drained crystal clear! I re-fitted the two drain plugs, then filled it to over-flow with jet fuel.
To cut a long story short, and a bit like when I cleaned the fuel tank, it was just a case of rotating the gearbox back and forth in the engine stand so the jet fuel could slosh and splosh about. After the first couple of sessions, thick black gunk poured out. Then for each subsequent flush, it ran clearer and clearer until the the 6th flush saw the jet fuel come out as clean as it went in which reassures me that it is now pretty clean in there.
To finish off, I thought now was as good a time as any to protect the gearbox as intended with my supa-dupa transit sealing wax spray. For those who don't know, this is a Valvoline product recommended to me by a fellow enthusiast, and is what must be the best kept secret in the industry. I've been experimenting with this stuff for a while now and can confirm that it sprays on in a very fine and thin mist which then takes a good few hours to go tacky, and a good few days to dry, then another few days to fully dry.
It sets a bit like candle wax, but is tougher to scratch off, won't chip, yet will come off with a decent solvent. As I go through the car, all the inner wheel arches, floor pans, suspension components - basically anything underneath or out of site will be drenched in this stuff. Pretty it isn't, but as a non-permanent anti corrosion protection coating that is vastly superior to the like of Waxoyl etc, it can't be beat.
Even when fully set, it still has a very very slight tackiness to it (you couldn't polish it for example) so with use, it will attract dirt and dust - but I'm not bothered by this at all - it can always be removed and re-applied whenever you desire, but will keep components sealed from the elements and in tip top condition. The final bonus is that it has a lovely golden amber colour to it.
In these last two pics, it is still very much wet ans I'd only just sprayed it on, deliberately avoiding the axles and starter motor apertures which can be gone over when everything is back in one piece.
Doesn't seem like 7 hours work, but that's what it was.
What else am I waiting for in the post....? Not just the axle spacers I can tell you!
I'm expecting from Italy a new pair of original BOGE rear shocks in the original red/brown colour. I've not been able to find any in the UK, as all the very latest stuff is now black, but good fortune saw me contacted by a guy who had a pair - still very new, so not NOS, but the best that is available in terms of OEM originality and colour.
Hope they are as good as my on-line translation software says they are....
Fingers crossed for some more action at the weekend!
