But mine's from Portugal, so why would I try and hide that?
That's what I don't understand?
Last Triumph wrote:
Just have the Portuguese plates remade then and put a metallic one on the front and rear bumpers when you drive it :!: :lol:
And back to my original question - how do they know it's an 'age related' plate and the other questions regarding numbers or letter first etc?
Last Triumph wrote:
Because most petrolheads can spot DVLA "age related" plates a mile off due to the sequence of letters used...XUF, XUX examples and just don't like them.
Now as you say, that doesn't really matter as you're proud of the car's heritage and its story, it's just I think we feel the car deserves a better "look" than just another DVLA sequenced number. Rich's 47 is a classic example. Registered as 813 UXU is now wears 43 TEV and looks a whole world better for it.
As to letter or numbers first, the following will make interesting reading! :beer:
A1 - YY9999 : 1903 - 1930's
Each council was issued with one or more letter codes for registering vehicles. Originally both one and two letter codes were issued as of 1903. This original system, using the one or two letter area code and one to four numbers (e.g. AA1 - AA9999) soon ran out and by the 1930's a change was needed.
AAA1 - YYY999 : 1930's - 1960's
It was decided an extra serial letter was to be introduced prefixing the original area code. This could only be used with two letter area codes, as prefixing a one letter area code would duplicate a two letter code, so the single letter area codes became obsolete. Serial letters were first introduced around 1932 as necessary. In order for the size of the plates to remain the same, a maximum of only three numbers (e.g. AAA234, GRF823) was used with this system. This serial letter ran in rotation with the numbers, so in the example ADE998, the "DE" is the area code (in this instance, Pembrokeshire County Council), and the A--998 runs in sequence. The next number in the Pembrokshire series would be ADE999, followed by BDE1 (note that no zeroes prefix the number 1).
1AAA - 999YYY : 1950's - 1960's
In the 1950's the system was reversed by councils who had run out of combinations in the previous series, now with the numbers prefixing the letters (e.g. 237RYU). A small number of councils ran out of these numbers by the late 1950's / early 1960's and as a temporary measure, four number / one or two letter area code registrations were issued (e.g. 2345AA). These did not have a serial letter, the one or two letters being the area codes as originally issued in the reversed format. Only the single letter area codes D,E,F,H,K,N,R,U and W were issued in this reversed format (e.g. 1042D) between 1953 and 1962. This was the last time the single letter area codes were used. Not all of these numbers were issued, making this type of number rarer than the ABC123 type.
