Some more pictures of the Disassembly .
The thing i love about this car ,the sunroof ,Now coming off .I have never removed one before but it was'nt too tricky to work out .It still has the leather slider pieces intact but there are some repairs needed to replace some captive nuts underneath.
Its amazing just how big that hole is on a 3 fold once you get the roof out.
This hole in the roof liner is where the car had some lodgers over a winter lay up.
Several moustraps removed them but the damage was done ,and the roof liner had to be removed .Here is the nest complete with mouse near the rear window.
Some parts packed way .I have kept a book of where everthing is as i know i will forget when it comes to put things back.
Tar board removed and all is well .
Sound pillows are intact but i need to remove them to inspect as i can see brown staining .
Only just noticed that the left side has had a small bump in the past .Picture doest show up to well but there is a small crease here.
Battery drill makes easy work of removing the bolts to remove the body.
Here is the frame i am using to lift the body as my rackety old shed is not up to hanging anything from.
As the 1938 beetle was recently married to its floor, mine is getting a divorce.Certainly makes it easier to remove the engine.I then spent a few hours hiding it in another shed.I will put the body back on after i have made something up to sit the body and floor at a good work height .This should be easier on my knees and I have some extraction to rig up as well as it can get quite dusty in there .
Edited at by user
