is this manifold correct for a split or zwitter !??
Thanks,
Guido  16016.jpg You have insufficient rights to see the content.
nev
  • nev
Hi Guido,
I would say only the K manifolds were originally fitted to splits but I understand later 30 Hp manifolds were modified by the factory as replacement parts. There is loads of info about early manifolds on the split forum on the samba you just need to do a search, you will need to measure the outside diameter of the ends of the inlet to confirm what you have there (25 or 30Hp)
Regards
Kevin
