I may end up fitting a 1500 6v motor in my `58 to get me back on the road.
What flywheel and clutch do these have? Will a normal 6v starter work or is there some kind of oddball oney year only starter that goes with them? I´m hoping it´s 6v size and teeth but with a bigger 200mm clutch. Anyone know for sure? The motor is from a 66 or 67 Beetle.
If its a 6 volt 1500 with its original flywheel etc i think it will go straight in.
If it has no flywheel on it then you may have to look at the specs of the clutch sizes for that year engine.The 1500 van may have come with a bigger clutch also you will have to see what the diamiter of the flywheal is on the engine you take out and make sure the new one is the same size for clearence on the bell housing ( we dont want to start having to grind it out to make it fit )
I think that the all flywheel fittings to the crank are the same just make sure you set up the end flote and make sure the gland bolt is tight!!!!!!!!!!!!!
As for the starter iv its a 6 volt flywheel then you should have no problems. Hope this is of some help.
AW wrote:
This is what I´m hoping! I could just forsee it having some goofy one year only parts, the way my luck with the car has been lately. Isuppose I should just go and look at it and take a 6v starter to see if it´ll mesh on the starter.
thanks
Keep us posted on the transplant :thumbup:
What's up with your motor then JD?
You may remember I pulled the tired original to fit a hot 30hp and had nothing but problems. For months.
I don´t want to risk doing any more serious damage to it, as it isn´t right, and I don´t trust it. I went to jump start it the other day (it´s stood so long, battery is flat) and it immediately puked about two litres of oil out under the car. I´ve had enough! I want my car back!! So I´m looking for the easiest solution, which may be this 1500.
Is that the one with the Wolfsburg West Okrasa kit? Where did the oil dump out from?
Thats the one. Not 100% sure, but most likely the cooler seals.
N2C_coxiste
Hello,
I heard about 2 versions, one on buss with good size (270mm), this one for buss with old gearbox with reducers and 1500.
The other one is a 275mm and need place into the gearbox...
Greg.
I ended up putting a 180mm flywheel on and a Berg heavy duty clutch. It´s been fine.
