simonhanloncole
Can i put a 12 volt starter straight onto my 1967 bug in place of the original 6 volt one. I heard that in 67 the 6v starters are the same as the later ones in size any one confirm this or is itr a case of buyig the starter and suck it and see.
thanks
Simon.
That works perfekt !
But I would let the 6 volt starter in the car !
I was driving and starting a beetle for years like that (12 volt)
Guido
I used a 6volt starter with 12volts for a long time too - BUT - you will eventually tear the teeth off your flywheel.
Just leave the car 6 volt! Its the easiest solution.
Jules
"JD" wrote:
I agree, I would do that too!
Nic B-C
Dont forget to change bush if you do this
check out www.durhamdubbers.co.uk great for resto threads 🙂
