With a rare day off, I hit the garage again with the aim to get organized for the engine rebuild. Seeing it sat there on the garage floor was just too tempting, so I did a quick supermarket sweep around the garage and with an arm full of tools, began to remove stuff…
Firstly I needed to remove the exhaust and heater boxes. My new best friend is plusgas – I cannot put in to words how wonderful this stuff is. I gave the exhaust studs a quick squirt the other day, and another go last night, and all 8 nuts came off without incident. In fact, every single fastener on the entire engine came off perfectly thanks to this stuff. Two of the studs came out the head, which is no problem and far better than them snapping, that’s for sure!
I was very impressed with the condition of the heater boxes – no rot through anywhere and just need a good clean up and rebuild. I’ll still fit the NOS ones though and keep these for spares. The lower tinware came off no problem – I always wanted to know how it all worked in there…
At this point it became blindingly obvious that it was a good idea to pull the motor, as the crud in the ports and all the cooling finds was extensive.
I then removed the inlet manifold, generator and fan housing, oil cooler and the rest of the tinware etc. Check out how much the cooling would have been impeded with all that gunk!
And then the clutch came off. No idea what this is supposed to look like, but from what I can see, it looks like a decent unit with plenty of meat left on the bone. I might replace it with a new one anyway.
At this point, I had a delivery of my new Empi engine stand!
On my way back to the garage, I noticed it was getting a little crowded in parts! Very unlike me, but what the hell, I was having a great time.
So….. the moment of truth – off with the heads! But before I did, I removed the rockers and pushrods, making sure I kept a note of which one went were etc.
I guess I now know why there was no compression on three of the cylinders now!
Yup – stuck exhaust valves.
The pistons and cylinders on the face of it, whilst coated in plenty of crusty carbon etc, actually look pretty good. The cylinders are obviously full of all the redex etc I poured into them, but there are no immediate issues jumping out at me, although I’ll have a better idea of their condition once I pull them apart and clean them properly.
Then out came one of my favourite tools ever – the torque master!
Gland nut? Piece of cake – highly recommended.
At this point I was starting to run out of space, so had to kerb my enthusiasm and get a bit of order back into the equation.
I assembled some shelving to keep the parts in a safe and orderly fashion.
And finally, I set up the motor mount on the bench, which I duly reinforced somewhat to ensure it was solidly mounted.
This is where I’ll be spending many an hour in the weeks to come I’m sure.
Not bad for one day…..
