I never thought this possible of anything, but cleaning the inside of crank cases both sucks and blows!
Oh, and Dad, if you're reading this, it means that I did indeed remember to lock the door behind me when I came round earlier when you were out to 'borrow' your pressure washer, and that theives haven't stolen your computer? Hope you don't mind?
And could I ask that you buy beer in bottles from now on, as cans just don't taste the same...
It was time to clean the inside of the crankcase, and whilst the jet fuel is a very gentle and kind substance to soak things in, I needed something a bit more powerful to get in all the nooks and crannies. After some research, I bought these to try.
So, after a good soaking of one half of the case in the gunk and the other half in the Swarfega as an experiment, and with Dad's power washer on standby, I found a suitable vessle to do the cleaning in...
A wheelie bin has never been so useful - Doesn't he look a dick!
For the record, both products worked well, but with a concentration of 10:1 or less, the Swarfega has the edge and had that 'solvent' feel to it even though it isn't, as the Gunk left an oily residue that I felt still needed cleaning off. I'm sure that if it was applied almost neat, the Swarfega would be awesome, but I followed the instructions and all went well - to a point...
The two products got the majority of the heavy gunk off, but despite endless pressure washing, there was lots of 'black' left in the corners and edges etc that needed hard brushing to disturb - joy...
So, I decided to experiment with a degreasing mixture of my own. There was no science to it, other than what I had lying around, so I mixed in approximately equal preportions, neat Swarfega, concentrated screenwash, brake cleaner, cellulose thinners and liquid soap. Smelt good enough to drink!
Wish I'd tried this to start with as it was absolutely amazing when sprayed on with plant sprayer, left to soak for 2 mins, then blasted off, the crud just washed away - most pleased.
Even though I'd held the pressure nozzle over each of the oil galleries for ages, I still filled them with brake cleaner and left to soak for 10 mins before blasting them with 120 psi from the air line.
This shot shows what came out of the other gallery on the right hand main bearing carrier - I did this several times until they were totally clean.
I'll do a final brake cleaner, tooth brush and lint free cloth clean by hand when it's time to put it back together, but it's nearly there now.
Here they are back in the garage soaked in WD40 awaiting some more love.
The comedy moment was when I realised that I'd blown out the main bearing locator pins with the airline, somewhere in the garden.... Do'h!
Would you believe that I found them all by accident, almost side by side on the other side of the garden without even having to look! Awesome!
