9 years ago
Now the first pivotpart is welded to hinge joint and prefitted to the b-pillar parts. This week the b-pillars will be welded!
The HebsterWerks.
9 years ago
Finally some welding again! :)
The HebsterWerks.
9 years ago
Had to take a brake in the garage when our 6 year old got sick. So we sat at home cutting some cardboard to figure out the final geometry of all moving parts of the frame… :)
Short vidclip here..
The HebsterWerks.
9 years ago
Damn!
I am so glad I have the original frame and do not have to do this for my car.
Looks like a hell of a job.
But also looks like it will work in the end.
9 years ago
I like the little challenge envolved in this work. And at the end it is not that complicated..
Well. I have had a lot of help from Peter to be able to visualize this. πŸ™‚
The HebsterWerks.
9 years ago
Next pieces in the puzzle! :d
The HebsterWerks.
9 years ago
Hinges done! πŸ˜ƒ
The HebsterWerks.
9 years ago
Now I have finished the main parts and tested to mock them up. Next is making all small detail parts so I can finally assemble the frame... πŸ™‚
The HebsterWerks.
9 years ago
Today I had to start mock up the shape and height of the main bows... πŸ™‚
The HebsterWerks.
9 years ago
Now I will not be able to go out to the car garage for two weeks due to winter holidays etc. But decided to work some "at distance" at home instead… So I started some woodworking out of Maple. Cut the big trees and chopped to suitable lengths 14 years ago with the thought of using for this cab frame…
So, here is the first part for the main bow… (Yes, I also have made the wooden table many years ago… πŸ˜‰ )
The HebsterWerks.
9 years ago
YouΒ΄re really cracking on with this. Keep it up!
9 years ago
All parts cut for rear upper bow. What is the thickness on the middle on originals?
The HebsterWerks.
9 years ago
In the middle. 71 Millimeters high and 20 Millimeters thick.
Along the lower edge there is an area where the thicknes goes down from the 20 to 15 Millimeters.
9 years ago
Oh, the rear UPPER bow.
I check that one also.
Just a Minute.
9 years ago
Number 1 is in the middle 30 Millimeters thick and 32 Millimeters high.
Number 2 is in the middle 30 Millimeters thick and 28 Millimeters high.
9 years ago
Thank you! Was aiming at 30mm x 30mm so I was not too far off... πŸ™‚
The HebsterWerks.
9 years ago
Would it be possible to get a photo where 2 is placed on top of 1 just to see if the lenghts differ much and also for comparison of the shapes.. ? πŸ™‚
The HebsterWerks.
9 years ago
I can make one tomorrow.
9 years ago
Glued and raw sawed.. πŸ™‚ Now to plane it to 31mm thick and then cut the bow shape.. :)
The HebsterWerks.
9 years ago
Here we go.
My new ones are already screwed to the metal frame.
I made pics of the old original ones.
