Hi folks,
Was wondering if anyone can check that I’m on the right lines with this problem. I’m having trouble starting my car, a 53 oval running on 6V with the 30HP engine. The starter motor seems to turn over very slowly at first then gradually picks up speed after about 20-30 turns, but by then the battery starts going flat. Fuel is getting through, the plugs are sparking and I’ve tried different batteries although both seem to go flat pretty quickly.
My thoughts are that the starter isn’t turning the engine over quick enough to vaporise the fuel correctly, but as this is my first car running 6V I’m not sure how quickly the starter should turn.
A friend suggested that it may be due to wear in the starter support bush in the gearbox but I’d have thought this would have led to the starter not engaging properly or jumping out of mesh with the fly wheel.
Any thought would be very welcome.
Cheers,
John
"Bert53" wrote:
